So I'm not the most tech-savvy person out there, but I do feel like after enough time on google I'm able to fix any problems I have, but I cannot solve this one. Here is the situation:
I noticed about 3 or 4 weeks ago my phone (Samsung Galaxy S 4G) would randomly turn off, maybe once or twice a week. When it rebooted, all of my apps on the SD card would not work. On the desktop screen, shortcuts were replaced by the generic green Android icon, and when I'd click on them nothing would happen. In searching online, this seemed to be a fairly common issue that was resolved by reformatting the SD Card. I did that, but it still has solved nothing. The weird thing is, and this is different from anything I've read, is that all of my photos are accessible still, as are my videos. It's only the apps themselves that do not work.
Also, when I go to Setting --> Applications --> Manage Applications, all of the SD Card apps, instead of having that generic green Android icon, they're that generic icon but they're GRAY, and in the lower righthand corner it says 'SD.' Clicking on these icons gives me the option to uninstall the app, but not to move it as it typically the case.
I think those are all the important details. If there's anything else you need to know or think important, please let me know. I'm not sure if it's the SD Card itself that just needs to be replaced, but I figured I'd try other remedies first before buying a new one.
If anyone can give my any insight into how to fix this problem I would greatly appreciate it. Thank you so much!
