1. Armorplays's Avatar
    I need help finding out if this is the outer glass lens or the digitizer
    10-07-2013 09:59 AM
  2. Paul627g's Avatar
    That would be the glass lens. Hopefully the digitizer wasn't damaged underneath. If this was just a drop to the ground that did this damage your digitizer is probably okay.
    10-07-2013 10:06 AM
  3. Armorplays's Avatar
    Would you know about how to replace the lens for this phone specifically or a similar way to
    10-07-2013 10:11 AM
  4. Paul627g's Avatar
    The method for the S3/S4 isn't the easiest. There are plenty of YouTube videos available showing how the replacement is done and TBH this is one area I feel more comfortable paying a local repair shop to do the work. Yeah it blows throwing away money on having someone else do it but in the event something is damaged (like the digitizer) in the process its covered by them...
    Main reason I say this is the S3/S4 display is glued down and involves a heating process to remove it and if your not very careful the digitizer can be destroyed.
    Armorplays likes this.
    10-07-2013 10:18 AM
  1. Galaxy Tab GT P1000 - samsung tab is STUCK. PLEASE HELP
    By quakquakquak in forum General Help and How To
    Last Post: 10-24-2014, 10:18 PM
  2. Help removing Android revolution rom and Teamwin recovery.
    By b- in forum HTC One Rooting, ROMs & Hacks
    Last Post: 10-18-2013, 08:52 AM
  3. T-Mobile LG G2 - Not getting Hangout notifications on G2 at all
    By joshua.worth in forum T-Mobile LG G2
    Last Post: 10-10-2013, 07:50 PM
  4. T-Mobile Online & Pre-Orders Backordered but Stores have Stock!
    By DalTXJim in forum Samsung Galaxy Note 3
    Last Post: 10-07-2013, 02:13 PM
  5. SGS 3 - Saving Music files.
    By Firefighter217 in forum Samsung Galaxy S3
    Last Post: 10-07-2013, 11:07 AM
