Notification light replacement
vinny jr
119
5
In the market for free there is an app called "noled" it works pretty good. It gives you a different colored light for different notifications. It even has a charging light. You can set it up to shut off at night. Check it out, made for devices like the SG2.
DrLouie
147
6
Which LED would it use for notifications? Mine doesn't appear to have a notification LED of any sort and I will admit that is one thing I miss from my BlackBerry days.
dougE2483
48
4
That app doesn't really use an LED on your phone as a notification light, but it uses the screen and displays little icons or whatever you pick from the app to display on a black screen. Only downside to this is i assume your screen has to stay on when a notification is on it or it might prevent your phone from sleep which in the end i would assume would lead to a shorter battery life then someone without using it.
vinny jr
119
5
The screen does not have to remain on, uses very little battery power. Try it, if you don't like it get rid of it. I need the notification light.
lunchBB
58
My previous Tmo G2X also doesn't have notification. Then there was an app in market to turn the 4 buttons into notification. Hope there is one for this phone.
Bbobarino
4
Yes its bln control app but u need a kernal that supports it. I am using juggs. 3.0 and it supports bln, I love it
Sent from my SGH-T989 using Tapatalk
jm_rookie2
