1. Shige1120's Avatar
    I am having a problem with mt battery port.It is loose.Any suggestions where I can get it fixed and how much would it cost?
    06-24-2012 11:24 PM
  2. blooper's Avatar
    Thats an odd issue to have. Does the battery come loose enough to disconnect the power from your phone? I could see why this could be a problem. If its serious and there arent any signs of damages done by you, it sounds like you can have tmo replace it under a manufacturer defect.
    Otherwise id just suggest wedging a small sliver of tape between the battery and the port to keep it secured.
    06-25-2012 12:43 AM
  3. Shige1120's Avatar
    im gonna replace on my own.
    New OEM Charger Port Connector Repair Parts for T-Mobile - Samsung Galaxy 2 T989 | eBay
    do you know where I can find instructions replacing it?
    06-25-2012 07:46 PM
  4. taylorz_412's Avatar
    Try YouTube
    06-25-2012 09:03 PM
  5. blooper's Avatar
    nice... so youve been talking about the USB charging port this whole time.
    06-26-2012 12:47 PM
