1. b727's Avatar
    Hi all,
    Something very strange happened last night, my phone rang and I looked at the caller number and it showed 1;1. I called back and the screen says "USSD code running...", after a couple of seconds says "MMI complete".
    I called T-Mo support and of course they don't know what I'm talking about. Has anyone experienced this?
    Should I worry about Spyware?
    I researched the internet for hours and no information about this.
    Any help will be greatly appreciated.
    My phone: Samsung GS2 running the latest official firmware.
    Thanks.
    04-02-2013 10:28 AM
  2. jdbii's Avatar
    Don't know what any of that is, but I would say if your phone is running sluggish, or if it just feels like something is making it feel a bit more buggy than before you got those weird messages, then maybe I would think it might be some kind of malware or other problem with the phone's OS. Otherwise I (talking about myself) wouldn't be too worried about it.
    04-03-2013 03:17 AM
  3. xKrNMBoYx's Avatar
    USSD Codes are a set of numbers and symbols entered into the dialpad of a smartphone (most Samsung). Each set of codes have a specific thing they do. I can't really explain it so I'll post a few links about them. You have to becareful with these codes. Last year there was that rave about the USSD codes that could be run by clicking on a bad link set up by a hacker that could reset your whole phone. A connection can be made between two devices with some codes. To be safe I would install a virus/malaware scanner and try a system scan of your phone. If it keeps on running sluggish you should probably reset your phone anyway.
    [REF] List of USSD codes! [Updated 10-30] - xda-developers
    Unstructured Supplementary Service Data - Wikipedia, the free encyclopedia
    jdbii likes this.
    04-04-2013 11:24 AM
  1. Replies: 5
    Last Post: 05-14-2012, 01:28 PM
  2. Need help with call log and default folders
    By JohnnyUtah in forum AT&T ATRIX
    Last Post: 03-21-2011, 03:44 AM
  3. Need help with an extremely annoying issue on my Incredible.
    By acman319 in forum General Help and How To
    Last Post: 03-15-2011, 07:56 PM
  4. need help with roots roms and so forth
    By BeansTown in forum Droid 2 Rooting, ROMs, and Hacks
    Last Post: 01-26-2011, 01:39 PM
  5. NEED help with buying X and Verizons site..
    By Austin-Black#AC in forum Motorola Droid X
    Last Post: 12-12-2010, 10:33 PM
