1. philip145123's Avatar
    Okay recently i've been trying to un-root my phone completely by installing the stock rom from odin and when i tried to do that my phone would just not work so while it was soft bricked/Continous Samsung Flashing i decided i would download Cwm again and just try and re-flash another rom just to get the phone to open up and i did just that than when i did my phone is now wacky and seems sluggish and my phone is also begging to crash can anyone help me ?
    Btw i attempted to un-root my phone because i wanted to play puzzles and dragons Jpn Version which requires no root any help would be amazing thanks
    04-30-2013 07:08 PM
  2. philip145123's Avatar
    200 VIEWS NOT one reply o.O?
    04-30-2013 09:00 PM
  3. Jacob Barfield's Avatar
    Galaxy S2 Unroot | Galaxy S2 Root I've had that problem before on my galaxy s2. Because I was messing around with CM 10.1 stuff. So now I'm back to CM 10 stable and waiting for the stable version of CM 10.1. Idk if this will help you but maybe it will.
    05-01-2013 12:28 AM
  4. HNNNNNGHHH's Avatar
    Another fellow CyanogenMod 10 stable build user? The CM10.1 M3 snapshot builds are plenty stable enough to use as a daily driver. Problem is that app/game graphics seem to be degraded when comparing it to CM10. There's also much more lag than what is expected of AOSP-based ROMs, almost reminiscent of TouchWiz IMO.
    However, if you'd like to prove me wrong, give me a little proof and I'll give it another shot. I was a tad bit too hard on it just because my blasted GBA and SNES emulators kept of getting FC's on CM10.1.
    05-01-2013 07:45 PM
  5. philip145123's Avatar
    I tried that already by unrooting it didn't unroot it just went infinite boot screen o.O
    05-01-2013 08:12 PM
  6. Jacob Barfield's Avatar
    I used the M1 build when I did that so that's probably why I just went back. Plus my S2 mainly get's used as a music player/games/internet. I don't know how CM 10 or even 10.1 works as a daily driver phone build, because I don't use my S2 as a phone. It's just my secondary device. When I used a S2 for a phone I didn't root it or anything just kept it stock and used it as a phone and everything else. But now that my s2 is my secondary phone I have a custom rom and everything on it. I use a Nexus 4 as my main phone. Well worth the 350$. Oh and Philip did you have the newest version of odin? that's what happen to me at first but once I flashed the stock ICS rom on with odin that fixed it and just rooted again. Then went back to CM 10.
    05-02-2013 09:12 AM
  7. philip145123's Avatar
    It worked before :/ But i have odin v1.85
    05-02-2013 04:12 PM
  8. philip145123's Avatar
    Really annoying i decided to unroot and now it wont even work and my phone becomes like derpy now -.- because my phone will now auto-restart and auto everything ITS SOOOO ANNOYING
    05-02-2013 04:14 PM
  1. New Droid X, freshly rooted.. now I need a bit of help.
    By Missy101 in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 02-23-2012, 08:08 PM
  2. Need a bit of help.
    By jbeastafer in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 07-22-2011, 10:29 AM
  3. Need a bit of help with replacement (warranty) evo
    By infoe in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 06-15-2011, 11:36 PM
  4. need a bit of help recovering my phone..
    By whyaphoenix in forum Virgin Mobile Optimus V
    Last Post: 03-25-2011, 11:09 AM
  5. Wanting to convert form BB, need a bit of help
    By aim4squirrels#AC in forum Motorola Droid X
    Last Post: 10-30-2010, 03:36 PM
