Echo Feedback when using phone
Shilohjerry
14
Sometimes I get a distracting feedback echo of my voice while talking. The person I am talking to sounds fine, but the echo occurs when I talk. Though this doesn't happen during every call, it is a distraction.
Does anyone have any suggestions as to how I can end the occasional feedback echo? Thanks!
HNNNNNGHHH
675
It depends on the ROM. Most newer 4.2 ROMs have already fixed the issue but try turning on Noise Suppression within the dialer's settings.
Shilohjerry
14
So, I couldn't find where I turn on Noise Suppression. I couldn't find it anywhere. Can you list the paths to it? Thanks!
HNNNNNGHHH
675
Go to phone, click the menu button, then navigate in settings and scroll down until 'Noise Suppression' shows up. Tick the box to check mark it and the echo should be gone. Noise suppression also helps with complaints about muffled sound.
Shilohjerry
14
Thanks, that worked. Now I'll wait for a call that experiences the feedback and turn on the noise suppression. Again, thank you!
kerokekerol
