What does the Android 'power saving mode' actually do?
magnoliasouth
10
The only thing I can find that the Power Saving Mode does is shutting off sync and dimming your screen. Is that really all there is to it? This is not a matter of my decision to use it. I am simply trying to figure out its list of features, which is nowhere to be found. At least, I couldn't find it.
Many thanks and I have Android 4.0.4., if it matters.
magnoliasouth
10
Thank you for the replies. The problem is that this doesn't really answer the question. I know how to use it, I know the tips. What I'm wanting to know is what does IT do when in power saving mode (not to be confused with custom power saving mode)?
I guess the answer is that there is no answer. That's too bad.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,582
4,724
113
From the above links:
"CPU power saving
Screen power saving
Turn off haptic feedback"
(CPU power saving probably caps the processor speed at a lower speed.)
I don't quite understand what you mean when you ask what does IT do when in power saving mode. It's following the protocols of the power saving mode. The default power saving mode is likely what you first see if you select Custom Power Saving.
msndrstood
1,619
7
38
I have noticed when I have it on my Note 2, there is a lot, and I mean a lot, of stutter when scrolling pages. I leave it off.
Sent via Note II
unirockers
