1. AC Question's Avatar
    My LG g2 is running slow I would type something and it would take fifteen seconds to register. My 4g lte connection would drop off then come back a little while later I've called t-mobile several times. also called lg a couple times and then the redirected to call Google techtech support all with no solution is either have to restart my phone every single day and did multiple factory resets and then I have to remember every single password that I have for different accounts Thera got to be a simpler solution any advice I'm ready to contact one of the CEO in fedfed with all this nonsense
    06-19-2015 12:51 PM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    Do you have a lot of apps installed?
    06-19-2015 01:48 PM
  3. claud rapoza's Avatar
    square button on bottom then clear all
    07-19-2015 03:55 PM
  4. korab84's Avatar
    The phone needs to move to Android 5.1.1 and everything will be awesome. With 5.0.2 I think there are some memory leak issues and they got fixed, so far, with 5.1.1
    Posted via VZW LG G2
    07-21-2015 01:49 PM
  1. LG G3 shuts down almost every day
    By JohnASmith in forum LG G3
    Last Post: 12-13-2015, 11:59 AM
  2. How do I get my Play Store back if it got deleted?
    By AC Question in forum Google Play Store
    Last Post: 06-22-2015, 09:25 AM
  3. Replies: 1
    Last Post: 06-22-2015, 09:24 AM
  4. My battery won't charge
    Last Post: 06-19-2015, 01:51 PM
  5. Replies: 1
    Last Post: 06-19-2015, 01:50 PM
