1. Felines-R-Me's Avatar
    I'm about to yank out each of my gray hairs. I've had an LG G2 (D801) with T-mobile since Feb 2014 and am on KitKat 4.4.2.
    I have my screen display time-out set to 15 seconds. For the past 6-8 weeks, that screen time out is NOT working and my screen stays on almost all of the time. Rebooting doesn't help. Same situation whether I have the phone in the quick cover case or not.
    The battery stats show "screen" as using anywhere from 52-65+% and it drains faster than fast. I do not have WiFi, bluetooth or anything enabled and turned off location. Only app I have is PrivacyStar for call blocking but I've had that for well over a year.
    T-mobile wants to blame the quick cover case, but the screen staying on happens whether the phone is in the case or not. I will be very grateful for help/tips you can give. Thanks very much.
    07-24-2015 08:52 AM
  2. UnlockedOnly's Avatar
    start fresh, back up and do a factory reset.
    07-25-2015 10:50 PM
  3. anduril92's Avatar
    you ought save all your data. Then you do a factory reset for to restore your LG.
    09-24-2015 02:58 AM
  1. Audiobooks on Android Auto
    By thehoz in forum Android Auto
    Last Post: 07-24-2015, 10:40 AM
  2. Why is my LG G2 always searching for location?
    By AC Question in forum LG G2
    Last Post: 07-24-2015, 09:15 AM
  3. Replies: 1
    Last Post: 07-24-2015, 09:02 AM
  4. Replies: 1
    Last Post: 07-24-2015, 09:00 AM
  5. Bluetooth issue
    By doogan123 in forum HTC One M8
    Last Post: 07-24-2015, 08:16 AM
