1. turinreza's Avatar
    i have adb 2.3 installed (eclipse and android sdk 2.3)
    I am able to mount the phone's sdcard in windows 7 explorer and
    see the contents. I guess this means the fastbook for USB works okay
    but adb is not seeing the device. "no device"
    (on phone , applicatoin debuggin is set to true...
    and USB storage turned off for when using adb)
    also "Stay awake" on..
    is there a website for updated Samsung drivers where I can obtain one
    for the Nexus S. I installed SAMSUNG_USB_Driver_for_Mobile_Phones_x86.exe
    (32 bit machine)
    and it didnt have a driver for Nexus S.. said " no driver found"
    01-14-2011 01:35 PM
  2. turinreza's Avatar
    in Control Panel, Device Manager
    it shows up in "Other Devices" as "Nexus S"
    no driver is loaded.. also
    I tried to update the driver "online" but that didnt work either.
    01-14-2011 02:11 PM
  3. turinreza's Avatar
    AVD manager has USB drivers Revision 4 that supports Nexus S under "Add Ons"
    01-14-2011 02:32 PM
