1. sprunknwn's Avatar
    Hello all,
    Is there a way to customize the opening and closing screen when I turn the note 3 on and off...?
    Thanks in advance,
    S
    11-24-2013 06:38 AM
  2. fantom305's Avatar
    I am not 100 % sure but I would say not unless you root.
    11-29-2013 11:46 PM
  3. thymeless's Avatar
    Root is the way if you want to be sure. Root your device, then go and rename/delete the poweron.wav poweroff.wav files. There are some apps, but there is no guarantee it works with every phone/carrier. https://play.google.com/store/apps/d...web.silentboot claims Note 3 compatibility but I haven't tried it.
    11-30-2013 08:40 PM
  4. Almeuit's Avatar
    This. Root would be required.
    Sent from my T-Mobile Note 3 using AC Forums.
    11-30-2013 11:10 PM
  1. Lock Screen Is Now Calendar and Memo - How to Disable?
    By DifferentThan in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 03-11-2015, 06:19 AM
  2. Samsung Galaxy S3 - Issues with audio + songs.
    By Foxwald in forum Samsung Galaxy S3
    Last Post: 02-08-2014, 10:50 AM
  3. Verizon Galaxy S3 - slim bean rom help
    By TheJustPull in forum Verizon Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 11-29-2013, 08:33 PM
  4. Sprint Galaxy S3 - Rootable 4.3?
    By gotta have it android in forum Sprint Galaxy S III
    Last Post: 11-26-2013, 10:29 AM
  5. Replies: 0
    Last Post: 11-24-2013, 09:32 AM
