Problem- Had a 4.4.2 Note 3 which ran fairly well. Decided to upgrade to Lollipop and for the most part it was ok with the exception of not being able to set a pin for security. Everything worked including low battery usage. Subsequent factory resets never resolve this issue with setting a PIN. I resorted to Kies and re-flashed using Samsung's latest/greatest Lollipop (again). It corrected the PIN issue + restored root but introduced a new problem with no mobile connectivity to the Tmobile network. Attempts to manually define the APN, mobile network selection have not worked. Factory resets no good. Nothing!
Attempted Resolution - I rooted lollipop and then downgraded back to a stock ROM build (which is rooted as well) 4.4.2 .
Here's my issues. I still cannot connect to the Tmobile network. Everything else is fine but no mobile network connection. Again attempts to manually define the APN, mobile network selection have not worked. The SIM is good as it works in other devices just fine.
I fear I corrupted the IMEI As I get a IMEI Certi: FAIL, -4 when doing *#0011#*
However, the proper IMEI is listed in the Settings- STATUS section. This isn't a blacked listed phone either.
I am in the process of downloading "NF9[[odin]][[tar]]stock 4.4.2 tmobile NOTE 3 ONLY" from xda forums.
...based on research done. I intend to flash it again. I think the modem is hosed.
If anyone has any wisdom out there regarding this problem, please speak up.
If I'm on the wrong path let me know.
Appreciate the help in advance.
-B
-B
