1. marv2014's Avatar
    It's there a fix for no sound on calls for sg4 ? , I did all workarounds and nothing works , help please?
    11-26-2014 11:07 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Can you give more details? Did this just start, perhaps after a recent system update? Are you unable to hear the caller regardless of using the phone's earpiece, speakerphone, or a wired or Bluetooth headset? Have you spoken to T-Mobile about this? They might want to try a new SIM.
    11-27-2014 01:02 AM
  3. marv2014's Avatar
    Thanks for ur reply , yes I update the phone to kit kat 2 weeks ago , yes the phone does not work whit blue tooth or head set I was using hangouts to make calls but only work for a while same with wi fi calling
    11-27-2014 09:28 AM
  4. marv2014's Avatar
    Just try my old samsung blue tooth and so far it's working let's see for how long
    11-27-2014 10:16 AM
  5. B. Diddy's Avatar
    Try booting into Recovery Mode and wiping the cache partition, which won't erase any personal data: http://support.t-mobile.com/docs/DOC-5744
    If that doesn't work, try booting into Safe Mode, which prevents all 3rd party apps from starting up. Steps are in the above link as well.
    If it still doesn't work, I would talk to T-Mobile and let them know that the update they pushed rendered your phone unusable as a phone. Since they pushed the update, they're supposed to take responsibility for any problems the update causes. Ask if they can give you a replacement phone, unless they can figure out a way to fix it.
    11-28-2014 12:11 AM
  6. marv2014's Avatar
    Thanks, but after a lot of search a reading other forums I found a workaround and so far it's working if the problem comes back I will contact tmobile
    B. Diddy likes this.
    11-29-2014 08:01 AM
  7. B. Diddy's Avatar
    Great! Can you tell us what the workaround is?
    11-29-2014 12:16 PM
  8. marv2014's Avatar
    Yea just turn off "ok google" from all the screens , google + it's off too and so far its been working
    11-29-2014 04:08 PM
  9. marv2014's Avatar
    The problem it's back again ,I can only make calls when I'm on wi fi or when I'm using my Bluetooth that's I'm calling t-mobile
    12-02-2014 10:22 AM
  1. Replies: 6
    Last Post: 01-27-2018, 11:45 AM
  2. Advice on selling a rooted Rezound
    By smilejack1 in forum Verizon HTC Rezound
    Last Post: 11-28-2014, 10:00 PM
  3. My camera app is on the homescreen but it is not working, why?
    By Angry Redhead in forum General Help and How To
    Last Post: 11-28-2014, 12:06 AM
  4. Replies: 1
    Last Post: 11-27-2014, 01:13 AM
  5. Why can't I change any pictures on my apps?
    By Zalea Rose in forum LG Optimus Series
    Last Post: 11-27-2014, 01:03 AM
