1. mosorwvlad's Avatar
    Hello everybody, i installed a few days ago a software update wich was arround 300mb, and i did it over WiFi. After the update NFC and S Beam are.. well ...screwed !! My phone is not rooted. So the ON/OFF buttons in settings are greyed out. And in the battery settings NFC uses about 5 % to 20% it varies. I did a factory reset and still the problems are there. I don't use NFC, i haven't installed any apps for it. I think that the software update just screwed them. I installed NFC Check by Tapkey and it say it's deativated, but in the battery usage it shows NFC 4%. Hope you guys can help ! Samsung S4 gt-i9505 running lolipop 5.0.1, NFC and S Beam not working !-screenshot_2015-10-27-17-16-05.jpgSamsung S4 gt-i9505 running lolipop 5.0.1, NFC and S Beam not working !-screenshot_2015-10-27-19-41-35.jpgSamsung S4 gt-i9505 running lolipop 5.0.1, NFC and S Beam not working !-screenshot_2015-10-27-20-01-11.jpg
    10-27-2015 01:38 PM
  1. Replies: 1
    Last Post: 10-27-2015, 08:14 PM
  2. Replies: 1
    Last Post: 10-27-2015, 08:03 PM
  3. Why isn't my fast charge working?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 10-27-2015, 01:27 PM
  4. Replies: 0
    Last Post: 10-27-2015, 12:45 PM
