Closingracer
Banned
Re: Tmobile to introduce $40 single line plan with 500mb high speed data, and unl...
Then metro pcs is good choice which uses or will be using t-mobile service and for cheaper. Metro pcs is $40 including taxes so I really don't see how this plan has any "Value" to anybody since metro pics should be using the same service and cheaper
Sent from my SM-N900T
And they could go any amount of prepaid. Coverage is depending on area and you can't speak for all. For some metro or others may be bad and T-Moblie is good. All depends on the situation.
No one plan is good for all. Just like this plan may fit others better and sometimes it may not.
Sent from my T-Mobile Note 3 using AC Forums.
