1. dojistar's Avatar
    Hi everyone, i just got my lg nitro, i unlocked it, so i can use it with T-mobile and everything seem to work well except that i don't have internet. Tmobile say they don't have the phone to their database so they can't give me the settings and i should contact the manufacturer. LG says this is an ATT phone and they can't provide me as well... Any ideas?
    Thank you!
    12-27-2011 11:56 PM
  2. CuriousNoob's Avatar
    APN: epc.tmobile.com
    Proxy: not set
    Port: not set
    Username: none
    Password: ****
    Server: MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc MMS
    Proxy: 216.155.165.50
    MMS port: 8080
    MCC: 310 MNC:260
    Authentication Type: Not set APN Type: not set
    I'll post another one in a bit.
    01-11-2012 10:07 PM
  3. Rob Burke's Avatar
    Heeeelllllllppppp, anyone have the apn settings for the lg nitro to work on tmobile??? Everythings working except internet.please help.thanks
    04-20-2013 07:05 PM
