Originally Posted by
stan23 I have one of those outlets and the USB port does not provide enough juice to charge the N3, as well as other various USB devices I have. It seems to work on iphone though, since it does not require as much USB power.
Stan very true. the iPhone wants a .5 amp charge. Android supports 1 amp. The Note 3 will charge at 1 amp. it will hold charge at .5 amp (the drain = the charge) but at 2 amps it will charge fast. most older equipment is .5 so most likely the output on the outlet is .5, hence the issue.
