Re: AT&T Note 3: KitKat finally!
What ive noticed.. very smooth. . But sometimes when I go to type in messaging app stock.. it lags and letters dont show up at all.. and when music is on lock screen pressing play and pause butten is laggy as could be.. (spotify) other than that.. good job
I noticed much longer charge time after the updated to KitKat. Anyone experiencing the same issue?
Sent from my SAMSUNG-SM-N900A using Tapatalk
Something must be wrong. 5 attempts. Download it then when installing always fails at 27 %. Says install interrupted.
Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
Hhmmmm...just checked to see if I could do the update and mine tells me my software is up to date and no update is available.
Still on the 4.3
for those of you who are running 4.4.2 hows the battery life does it drain as bad as the t mobile variant??
Originally Posted by
aandrew610 for those of you who are running 4.4.2 hows the battery life does it drain as bad as the t mobile variant??
So far, I've noticed no difference at all. I typically lose 6-8% overnight (mostly due to various apps like BeyondPod syncing and downloading content) and was the same last night. Went to bed at 98% and woke up at 92%. We'll see how the first whole day goes today, but so far, so good.
Got my update with no issues and one of the first things I noticed is that the phone (when talking on it) is WAY louder. I thought I had hit the speaker by mistake. :eek:
Thanks for the reassurances! I'll wait a little bit yet before I take the plunge but overall, this update sounds very promising!
I think I'm starting to get jealous....Verizon last with updates ...as usual.
It looks like AT&T also added Beats Music as I did not have that before. It appears to be a subscription based service (free for 90 days and $15 /mo after that for up to 5 phones on your account). Figure I'll give it a try since it's 90 days. It takes you through a setup based on your specific music tastes. Oh and it's added to your AT&T bill after 90 days.
clitrenta It looks like AT&T also added Beats Music as I did not have that before. It appears to be a subscription based service (free for 90 days and $15 /mo after that for up to 5 phones on your account). Figure I'll give it a try since it's 90 days. It takes you through a setup based on your specific music tastes. Oh and it's added to your AT&T bill after 90 days.
It was only free for 5 days with my iphone5s. I liked it...not sure I'm willing to pay for it though. I have enough music on my Memory card
spencerdl It was only free for 5 days with my iphone5s. I liked it...not sure I'm willing to pay for it though. I have enough music on my Memory card
It's only 90 days when using a family plan. If it was just me, it wouldn't be a big deal but several of my family are into music enough where this would be beneficial so since it's 90 days free to try it, what could it hurt? So far I'm liking the way it works. I also can find just the songs I like and get rid of the ones I don't. Muchmore efficient way of maintaining only the music you like without buying stuff you don't like. Can't hurt to try it out.
Jake Cukich What ive noticed.. very smooth. . But sometimes when I go to type in messaging app stock.. it lags and letters dont show up at all.. and when music is on lock screen pressing play and pause butten is laggy as could be.. (spotify) other than that.. good job
Have you updated your Samsung hub app? I had these issues, then a friend recommended updating the Samsung hub app. It updates the core apps (I.e. messaging). Now the issues are gone.
rvhs03 Have you updated your Samsung hub app? I had these issues, then a friend recommended updating the Samsung hub app. It updates the core apps (I.e. messaging). Now the issues are gone.
Good to know....Thanks for the info
1 Attachment(s)
Hey everyone....a couple of update questions. When I go into my device info to check for updates, I get this message at the final screen:
Attachment 109885
Does this look right/ normal?
Battery life is either the same so far or maybe even better than 4.3.
jsreen Hey everyone....a couple of update questions. When I go into my device info to check for updates, I get this message at the final screen:
Attachment 109885
Me too. Can't figure it out. I've tried 5 times.
Ill try it thank you!
If I go into the app store and try and update it.. it says its not compatible with my device?
Downloaded and installed over lunch! Praise Zombie Jesus!
Now what?...
Wait for root and switch out the god awful dialer with the Nexus version?
Attachment 109885
I think the update is still rolling out by a region/timezone basis. I think people are getting over that by setting their clocks differently and turning off auto sync time.
charlee08 Battery life is either the same so far or maybe even better than 4.3.
I agree.
I am also getting the same message :(
I tried changing the date manually ..went as far as april 30 but could not get the update..
I've tried the time change thing too. I'm in Austin, TX for the record.
