Help! YouMail won't give me my voicemail back...
wendy5001
Active member
Mar 13, 2014
44
I broke up with YouMail and now I'm not getting any voicemails, I'm just sticking with AT&T for now. How do I get it back?
Sent from my SAMSUNG-SM-N900A using Tapatalk
mavrrick
834
3
There is a setting in the phone that dictates where the voice mail goes. I don't know how to get it back though without doing a factory reset. Probably have to input some service codes to do it.. You should be able to call ATT and have them help you reset it.
kentuc794
79
If you have you mail installed still there is a button to deactivate it. If you already uninstalled it the go to your phone click on settings buttons go to call settings. Then click on voicemail settings. You will need to find someone that has the same carrier to find the service number that you need to input.
Irek Roszkowski
Press those codes then CALL button after each:
##61# then "CALL"
##62# then "CALL"
##67# then "CALL"
This works for AT&T only and resets settings to third party voicemail services.
kixfan
1,060
16
38
Well now that a YouMail rep is here, how about telling me why it keeps logging itself out and not notifying me of voicemails until I open the app and login again? I'm pretty close to going back to AT&T voicemail too.
calvinxander08
