After a restore, the system is still pulling the most power. Any other way to fix?
just install 360 Security from play store, it wonders...After a restore, the system is still pulling the most power. Any other way to fix?
I was having the same problem...using about 15% battery every hour even with the screen off. I turned off the always allow scanning option and man what a difference. Going on 12 hours and still at 70% battery.
My question is, is that something you really want to turn off? I'm not sure. I assume that also means you have to remember to turn it on when you get home????
