After the lolipop update my s pen button doesn't work when I push it . Is that correct or is something wrong.
Same problem here and my Air Command setting Is enabled. The air command opens up at the start, I select image clip, but if I've messed up and need to start over pressing the button doesn't open up the air command anymore. If this function has been changed by Samsung with the latest lollipop update then I'm going to be really mad. The whole idea of having this phone was for the S pen since I'm an HTML Designer and need a phablet.
It's nothing to do with the Lollipop update. I have the same problem and I'm still on KitKat 4.4.2. Pretty annoying how it just stopped working.
Surprisingly, my issue was fixed after an upgrade to Lollipop. May be the only thing I like about it.
How is the S Pen supposed to behave anyway?
I dont believe I've ever got it to function "properly", either under KK or LP.
Mine acts like this - when the pen is in its holder I slip it out and the menu icon appears, I can select memo (for instance) and that invokes S Note. But once I've done a save no combination of gestures or taps recalls the menu.
Also the pen notification doesn't kick in until I've walked quite a ways away from where I've left the pen.
Have I got Air Command ON but still missed a setting?
