1. Reformed IOS User's Avatar
    To enable Wi-Fi hotspots I have to call att?
    What's up with that - does it cost extra?
    05-02-2013 03:33 PM
  2. satannik's Avatar
    Yes you have to pay. Although there is a way to bypass it with a few apps like foxfi
    Sent from my rooted Samsung Galaxy S 4
    05-02-2013 03:34 PM
  3. Almeuit's Avatar
    Yep and yep.
    Sent from my Sprint S3 using AC forums.
    05-02-2013 03:49 PM
  4. CehowardNote7's Avatar
    That is why I am going with T Mobile. nothing extra for hotspot, and you get 500mb of data on 5 devices hooked to the hotspot.
    ATT was the same way, they want extra for the hotspot.
    Right now, with the no contract option, T Mobile is looking good. Shucks, even cricket allows free tethering up to your data limit..
    Sprint the same way.Extra for hotspot! Sheesh!
    05-02-2013 04:12 PM
  5. Reformed IOS User's Avatar
    well ain't that a load of ...
    Need something free or 1 time cost to provide wifi to ipads without rooting
    05-02-2013 04:13 PM
  6. zhingket's Avatar
    Foxfi no root needed
    05-02-2013 04:42 PM
  7. JasW's Avatar
    +1000 on Foxfi. You can't d/l it from the Play store -- it's blocked for AT&T users -- but you can d/l the .apk file directly from the developer (for free). Just make sure you check the box under Settings > Security > Unknown sources to allow installation of apps outside of the Play store.
    05-03-2013 07:06 AM
  8. southflorida#CB's Avatar
    I was able to download and install. However, app shuts down each time "activate wifi hotspot"
    05-05-2013 06:46 PM
  9. gollum18's Avatar
    I'm pretty sure pdanet owns foxfi now. The free version is now ridiculously crippled and they make you have pdanet just to use it.
    Sent from my SPH-L710 using Tapatalk 2
    05-05-2013 07:18 PM
  10. gollum18's Avatar
    It's pretty funny they lock a feature down just so they can charge more for it.
    If you are rooted, you may be able to install wifi tether for root users, to get around it.
    05-05-2013 07:19 PM
  11. JasW's Avatar
    Totally worth it, and the $7.
    05-06-2013 06:39 AM
  12. jaltman's Avatar
    You dont necessarily have to "pay" for tethering. It comes included with lots of plans. My wife and I are on a family share plan with 4GB of data. That is adequate to our needs since we are both on wifi whenever we are at home or the office. Tethering is included in the plan. We have a 2d home in the mountains and tether two tablets the whole time we are there on the weekends and have still never gone over 4GB.
    Also, foxfi works great and I think the connection is more stable than the native hotspot alone.
    05-06-2013 06:55 AM
  13. Farish's Avatar
    Is foxfi/pdanet+ traceable?
    05-07-2013 11:15 PM
  14. sqa4life's Avatar
    This is funny. I also have AT&T and I was able to use hotspot on my BB z10, but not on the S4. Both phones have att official build.
    05-11-2013 01:56 AM
  1. Anyone know about or use "portable wifi hot spot free"
    By drmaf894c in forum Verizon Galaxy S III
    Last Post: 12-25-2012, 12:20 PM
  2. Anyone do Portable Wifi hot spot?
    By MrVivekB in forum Google Nexus 4
    Last Post: 11-05-2012, 11:43 PM
  3. VPN Access Not working with 4g WiFi Hot Spot
    By p08757 in forum Motorola Xoom
    Last Post: 10-28-2011, 08:48 AM
  4. WIFI Hot Spot Problem
    By lance1955 in forum Virgin Mobile Optimus V
    Last Post: 07-28-2011, 06:12 PM
  5. Wifi Hot Spot?
    By justinoutlaw in forum Motorola Droid X
    Last Post: 06-25-2010, 12:04 AM
