11-03-2013 02:54 AM
37 12
tools
  1. GS4Bob's Avatar
    http://forums.androidcentral.com/sho....php?p=2858412.
    Did not work for this person...I have tried two different 64gb cards with same issue.
    From my 32gb GS4 via Tapatalk
    06-16-2013 03:52 PM
  2. LordAndroid's Avatar
    I recently had a problem with a Sandisk 32gb card in my S4 where it started unmounting and remounting itself at random. Posted a thread here and someone said it is a known issue with the card itself. So, I ended up buying a different 32gb card, a Samsung 32gb, and it works just fine with no issues. I don't know if this is related to your issue or not.
    I just purchased a Samsung UHS-I 32g class 10 today so im awaiting its arrival. I will post and update as soon as i receive it.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
    06-16-2013 04:17 PM
  3. GS4Bob's Avatar
    Good luck with the Samsung.
    My Kingston worked well for three straight days....then I changed some files on the card and boom next boot..."damaged sdcard".
    06-20-2013 10:11 AM
  4. LordAndroid's Avatar
    came in todays mail
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 4 Beta
    06-20-2013 06:55 PM
  5. LordAndroid's Avatar
    I will be firmating switching out all my media on to this card today update to follow
    06-20-2013 06:56 PM
  6. LordAndroid's Avatar
    Ok so i formatted the ext SD card via the phone and it mounted fine transferred all my media over to it no issues yet hopefully it stays that way.
    06-21-2013 03:44 PM
  7. LordAndroid's Avatar
    A couple days in and all is well
    06-23-2013 01:19 PM
  8. LordAndroid's Avatar
    Almost a week all is well
    06-27-2013 07:20 PM
  9. LordAndroid's Avatar
    almost 3 weeks later since i last chimmed in all is well thus far with this SD card.
    07-17-2013 04:18 PM
  10. GS4Bob's Avatar
    The latest very large "update" via ATT has fixed this issue. No more "damaged sdcard" causing unmounted cards!
    My 64gb Kingston is working without any issues now.
    07-18-2013 10:44 AM
  11. and101an's Avatar
    According to Sandisk support when I talked to them around June, 2013, and all over the Amazon reviews for months, is a known incompatibility between the Sandisk Ultra Micro SD cards (possibly others), and the Galaxy phones (possibly others). The card can "fail" any time from days to many months down the road. Sandisk says that Samsung won't admit it, and so Sandisk created a ROM patch that is applied only during manufacturing, to circumvent the problem.
    Contact Sandisk for free replacement. I was told that the new card batch started after March, 2013, but the only way to tell, is based on a small serial number on the card, that requires a magnifying glass, if you can even then read it.
    I do not know if other cards from other mfgs are involved, but Sandisk says they have stepped in and solved it on theirs. Good luck!
    09-29-2013 02:37 AM
  12. thewamp's Avatar
    I found, on the Sandisk web site, that they have "Android" and "non Android" microsd cards. The following is shown for 32G cards:
    Memory Card with Adapter - Android
    Europe/Asia-Pacific/Latin America/Middle East & Africa
    SDSDQUA-032G-U46A - 32GB
    Memory Card with Adapter - non Android
    SDSDQU-032G-U46A - 32GB
    11-03-2013 02:54 AM
37 12
  1. Sandisk Micro SD 64GB $59.95 on Amazon
    By Cory Streater in forum Samsung Galaxy S III Accessories
    Last Post: 05-11-2013, 12:43 AM
  2. Samsung or sandisk micro sd?
    By mitz85 in forum AT&T Galaxy Note 2
    Last Post: 03-15-2013, 08:54 PM
  3. Problems with 64 gig sd card
    By Kazmandu in forum AT&T Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 12-13-2012, 02:49 AM
  4. Sandisk Micro SD 64GB $59.95 on Amazon
    By Cory Streater in forum Samsung Galaxy S3
    Last Post: 07-31-2012, 09:58 PM
  5. 32g sandisk micro sd
    By sarcosis in forum Other OS's and Devices
    Last Post: 05-22-2010, 09:13 PM
