Max SD card size?
thunda1010
14
I know the S4 can take Micro SD or Micro SDHC cards, but how large can the size be exactly? Waiting for a 64GB to come in the mail and just occurred to me that it might not be able to use all 64GB.
And also, out of curiosity, how do Samsung official cases compare to SanDisk? or what is the best micro SD card brand to buy from?
Farish
1,289
People have posted on these forums they have used their s4 with a 64gb.
jdub1981
1,382
That is the exact one I have in both my note 8 and note 2. Its fine. Plus its might or copying stuff to or reading from.
Sent from my GT-N5110 using Tapatalk 2
Fuego
Active member
Jun 10, 2010
34
I have a SanDisk 64 gb card in my S4. Works fine and plenty of head room.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 4 Beta
adam1314#IM
46
I have the SanDisk 64 GB in my S4 and it works fine. Almost have it completely full. I am ready for 128 GB SD cards to be common and supported!
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Droid4Core
16
The San disk 64 gig card is the best you can get. However: if your a speed freak and like nice things cyanogen mod has a nice option to speed it up... Which it does quite nicely
Sent from my SGH-I337 using AC Forums mobile app
wesboogy
I have a 4 gig Kingston sd in my s4 and my pic. Always freezes even when I'm looking at the pics my phone camera took has any one has this problem
Steve Maschue
Yes, I had the exact same problem. I installed a 64GB micro SD Card that was described as Class 10 and had no problem until I filled the card up to about 10 percent of it's capacity (about 6GB). Then the camera would freeze up at random times. When I went to look at the photos, I ran into similar problems. I isolated the problem, when I figured out that everything worked just fine with internal memory, without the SD card.
I then switched to a 32GB "Samsung" brand micro SD card, and have had no problems for the past 4 months. I believe the SD card has to be very fast in order to handle the photo & video storage from the camera. I would like to upgrade to a larger size card now. It seems hard to believe that I could fill up 32GB with music, photos, podcasts and videos --but it happens! I still haven't found out if I can upgrade to a 128GB micro SD card. Does anyone know? They are available now at reasonable prices. However I am concerned about finding one that is "fast enough" that I don't run into the problem I originally had with the 64GB card.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
It should work. The Sandisk 128gb microSDXC card worked on my note 3 and s3.
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
gxgs
75
This happened not because the card was slow or of an incompatible size, but because the card you bought was either a knock-off from ebay/amazon or somewhere else or damaged internally. That's what happens when they fake the size of the card by modifying... lets call them internal 'parameters', to show it as higher capacity, but in reality, its just a low GB card. Therefore, the card rejects any new files, and if it accepts them, they show up as corrupt, since there is no more space for it store more data. It just stores a 'pointer' to a non existing file in the partition table.
For everyone, buy SD cards from reputable sellers and from reputable brands. Cheap cards are cheap cards, or even fake ones.
metle_geek
1,018
You make me want to cancel my order off amazon for a data 64 gig
must have unlocked boot loaders!!
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
If you buy from amazon make sure that it is sold by Amazon.com and not a third-party
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
metle_geek
1,018
I would not buy an sd card from third party on Amazon, including FBA. Too many fakes. If you do buy it, make sure to test the sd card
Yea I canceled it packaging didn't look rite and it said micro sdhc not micro sdxc
dctokyo
216
Also have a look at Toshiba EXCERIA cards ( 90 MB/s Write and 95 MB/s Read Speed ) , I prefer made in Japan over Taiwan or China anyday
Cy3berOdyssey
