11-07-2016 01:34 AM
34 12
tools
  1. Gurpreet Soomal's Avatar
    Thanks guys, with the new 4.3 update it was really awkward to have the flash going off and this solved the problem on my S3
    However, I actually liked it when the flash went off during the alarm, is there any way I can have it to flash only for the original alarm which comes with the S3?
    Thanks!
    12-11-2013 03:17 PM
  2. jsbouch's Avatar
    My Galaxy S3 started doing it after the update too, it is SOOO annoying, especially when you have a dog that is obsessed with flashing lights :-(
    12-17-2013 06:25 AM
  3. Kerry Raddis's Avatar
    Thank you for mentioning the "Motion"! Fixed it for me
    I've an S3 that was just upgraded to 4.3 and this was extremely annoying. Totally incomprehensible why they would do this :/
    12-17-2013 05:01 PM
  4. thekA3's Avatar
    OK, found it! for anyone that this option is turned on from the factory to turn it off:
    Settings> my device > Accessibility > Flash notification!!
    THANK YOU!
    05-26-2014 04:57 PM
  5. Brenda Gooding's Avatar
    Thankyou...lol i had the same issue.
    08-18-2014 06:35 AM
  6. thebrunettewholoveshercar's Avatar
    I don't have this option on my phone (samsung galaxy express 2) do you know if there is another way for me to stop the flashing?
    Thanks
    12-08-2014 04:48 PM
  7. svavantsa's Avatar
    02-08-2015 07:36 PM
  8. svavantsa's Avatar
    Thank you so much. This was bugging me too for a while.
    02-08-2015 07:37 PM
  9. Lalz's Avatar
    Thanks a bunch! it was not turned on as well for me and I still seem to get this REALLY annoying flash, I was breaking my head trying to figure out!.
    I tried ur technique, seems to do the magic. its finally off! Phewwww!
    11-07-2016 01:34 AM
34 12
  1. Galaxy S4 incoming call voice command problem!
    By ronixbasumatary in forum Samsung Galaxy S4
    Last Post: 01-07-2014, 04:40 PM
  2. Is having the camera flash go off new for android or old..
    By HOLLYWOODANT215 in forum Samsung Galaxy S4
    Last Post: 05-21-2013, 02:29 AM
  3. Is there a way to silence incoming calls/texts?
    By J0LL3Y in forum Misc. Android Phones
    Last Post: 02-13-2012, 08:37 PM
  4. Any Way to Readout Incoming Call/Text ID?
    By AFirefighter in forum Verizon HTC Thunderbolt
    Last Post: 04-18-2011, 03:17 PM
  5. Anyone noticing their flash going off too soon with the camera?
    By GenericMessage in forum Motorola Droid
    Last Post: 06-10-2010, 09:46 AM
