1. Tasia Larsen's Avatar
    I just got the SG4, I really like it, however I have been stumped by the volume slider for media. I can slide every other option, but I can not figure out how to un-mute the media option. I've been through this forum, google, and the "instruction manual". Help! I'd like to listen to my music and videos!!
    -Tasia
    09-17-2013 01:12 AM
  2. Chief G-Hawk's Avatar
    I have this happen to me to whenever I put my phone into silent and then back to sound mode. Media seems to be disabled (sometimes but not always). But a simple fix for me is to hold the home button until the task bar opens, and tap on the left button (should be the circle with the pie graph icon), to get to view your RAM. What I do is free up RAM and this seems to fix my issue.
    Or simply hold the power button and restart.
    Ttwelve Tevi and Tasia Larsen like this.
    09-17-2013 08:37 AM
  3. Tasia Larsen's Avatar
    That worked!! Removing programs that were running from the que. Still learning more and more about this phone! Thanks!
    09-17-2013 12:50 PM
  4. Ttwelve Tevi's Avatar
    thanks a ton!! you saved my day, i just registered to thank you
    oh btw it worked on my note 3
    11-11-2014 08:26 AM
  5. edi73518's Avatar
    Good ol' power button did it on my Droid Turbo.
    08-21-2015 07:04 AM
  6. lynn623's Avatar
    This is the exact solution - clear the ram and your sound will work - thank you for the suggestion!
    03-17-2016 05:17 PM
  1. How To Get Amazon Prime Movies Working With Chromecast
    By Scutley in forum Google Chromecast
    Last Post: 05-06-2014, 06:25 PM
  2. Rooted phone straight talk calls text work but no data
    By Justin Wojciechowski in forum AT&T Galaxy S II
    Last Post: 10-20-2013, 12:00 PM
  3. Some T mobile Stores have the Galaxy Note 3 Early!
    By Preach2k in forum Samsung Galaxy Note 3
    Last Post: 09-29-2013, 07:25 AM
  4. LGL55C will not go to boot menu...help!!
    By Georgina Walker in forum General Help and How To
    Last Post: 09-17-2013, 09:20 AM
