1. sparker781's Avatar
    Hey All
    I got my phone setup with automatically display dimming and screen time out set at 15 seconds however the settings that tell you whats using your battery says that my display is at 55%. Is there a way to conserve my battery so I am not charging it every day?
    Thanks
    10-18-2013 01:15 PM
  2. Gekko's Avatar
    % listed is % of usage, not % of battery. if all you do is turn your display on and nothing else - display % will be disproportionately high. don't sweat the percentages.
    http://forums.androidcentral.com/son...ml#post3101802
    10-18-2013 01:48 PM
  1. Galaxy Note 2 Battery Drain Issue
    By Alberto Note 2 in forum Verizon Galaxy Note 2
    Last Post: 02-05-2014, 01:51 AM
  2. gs4 play store and battery life problems
    By mchockeyvette27 in forum Samsung Galaxy S4
    Last Post: 10-18-2013, 02:20 PM
  3. S4 battery recall ?
    By sulasno in forum Samsung Galaxy S4
    Last Post: 10-18-2013, 01:12 PM
  4. Android 4.3: Location Services battery drain?
    By pasei in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 10-18-2013, 01:05 PM
  5. Pretty awful battery life
    By JayInNJ in forum Samsung Galaxy S4
    Last Post: 10-18-2013, 11:57 AM
