1. Introvert4point0's Avatar
    I traded my iphone for this AT&T galaxy S4 2 weeks ago, the phone works good and all but i can't get it to update the software, its stuck on 4.2.2. I believe it was rooted, they did a manuf reset on the phone before i got it and it had an app installed called Superuser and when i reset the phone a little robot comes up and asks for recovery or continue, i think its called safestrap or something idk. and an unlocked padlock comes on the screen and says custom. I have never rooted a phone or owned a rooted phone so I have no earthly idea what to do to fix this issue. Any help would be greatly appreciated. thanks.
    09-18-2014 10:54 AM
  2. Slashyou's Avatar
    Its rooted then BUT use this youtube video: to get it back to stock and i recommend ONLY this one as your on 4.2.2 so is the video
    09-18-2014 11:13 AM
  3. Introvert4point0's Avatar
    Thank you very much i will give that a try right now. I appreciate the help :-)
    09-18-2014 11:19 AM
  4. SpookDroid's Avatar
    If the Superuser app is installed and you get those screens, then yes, your phone is rooted. I'm not sure if this blocks updates from AT&T or not, but I kinda remember that it does.
    Here are a few things you can try:
    1) Download Samsung Kies to your computer, connect your phone to it via USB and see if you see the update there.
    2) This needs a bit more reading and advanced 'trickery', but since your phone is rooted, you could download AT&T's newest software image (ROM) and install it manually onto your phone. This needs a couple more software components on your PC but since I haven't done any of that in a while, I'm not the best candidate to give you step-by-step guide on that. But those are in abundance online. You can also opt for another ROM instead of AT&T's as long as it's confirmed to work with your phone and carrier. Sometimes these custom ROMs are cleaner, snappier, and have none of the bloatware carriers love to add to our devices.
    3) Either have your phone 'unrooted' yourself or have someone else that has more experience with these tricks to do it for you.
    09-18-2014 11:23 AM
  1. What are some good photo editing apps for the Galaxy S5?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 10-24-2016, 01:20 AM
  2. LG3 or HTC One M8?
    By Bmilano3161 in forum Samsung Galaxy S5
    Last Post: 09-19-2014, 03:04 PM
  3. LG3 or HTC One M8?
    By Bmilano3161 in forum HTC One M8
    Last Post: 09-19-2014, 11:29 AM
  4. Samsung Galaxy S5 E-mail Issue
    By Unregistered in forum Ask a Question
    Last Post: 09-18-2014, 10:45 AM
  5. Galaxy S4 not updating, still on 4.2.2.
    By Introvert4point0 in forum Ask a Question
    Last Post: 09-18-2014, 10:29 AM
