1. eyeopen's Avatar
    Hi I just got my Galaxy S4 unlocked and it seemed fine, then I went to connect it to the computer on Vista and normally it opens up a box asking if I wish to add pics, videos etc, a box appears on the phone asking if I wana charge or connect phone. Even if it doesnt come up you can find it manually threw my computer.
    Now I got it unlocked I cant find it connected to the PC, Its not in my computer and when I went to system devices, and it comes up as Device Unknown, and says
    ! CDC Serial
    ! SAMSUNG_Android
    ! SAMSUNG_Android
    ! SAMSUNG_Android
    I dont know whats wrong I cant connect the Phone what is wrong how do I sort this thankx
    02-19-2015 01:39 PM
  2. Rukbat's Avatar
    Whoever unlocked it broke something. SIM unlocking has absolutely nothing to do with connecting to the computer. It's like not having oil in your engine gave you a flat tire - there's no connection between them.
    02-19-2015 03:17 PM
  3. eyeopen's Avatar
    Hi thankx I dont think its physical more software related, I had no idea unlocking was harmeful to samsung galaxy as it as on iphones
    It also doesnt let me do software update for phones (does let me update apps) after the unlocking too.
    02-19-2015 05:09 PM
  1. Samsung Galaxy S3 doenst charge with every USB cable?
    By skauder in forum Samsung Galaxy S3
    Last Post: 02-23-2015, 05:41 PM
  2. Why can you not write to external sd card with Android 5??
    Last Post: 02-20-2015, 12:11 AM
  3. Is there a way to flash an Samsung Tab back to Factory
    By Bill Fox1 in forum Samsung Galaxy Tab4 10.1
    Last Post: 02-19-2015, 03:55 PM
  4. Replies: 0
    Last Post: 02-19-2015, 01:31 PM
  5. How to update music player?
    By BunnyInDisguise in forum Samsung Galaxy S5
    Last Post: 02-19-2015, 01:21 PM
