1. abtelectronics's Avatar
    forgot the pattern to the samsung infuse how to reset it to a factory mode? please help
    06-15-2011 05:04 PM
  2. cordoni's Avatar
    Take it in to a At&T company store and they can unlock it for you.
    06-15-2011 05:58 PM
  3. u1988's Avatar
    www.hard-reset.com - Samsung i997 Infuse 4G hard reset - PDA Smartphone PNA hard reset soft reset
    factory reset
    in settings-privacy-factory data reaset
    *but go in to the link up there is a warning...that it will delete every thing....
    maby not the contacts ,but I was backing up everything to my computer
    just to make sure...
    guide backup contacts...
    http://www.all-samsungphones.com/sam...contacts.html/
    hoping that help you
    06-15-2011 07:47 PM
