10 Percent battery fix anyone?
the issue is once the phones charges 100% it stops charging and begins to use the battery then begins charging again and its using more then its taking in thus you go from 100 to 90 in seconds becasue it has to re adjust itself really quick
Someone else has run a test using a device that measures the current draw at the charger. He's shown that once the phone reaches 100% the charger stops drawing current. If he runs operations that drain the battery, the charger continues to draw zero for some period of time, but eventually the battery drops to a level that causes the charger to kick back in.
Now that I've gone back and looked at your results, and scrolled right to see everything, your results seem to confirm the above. At 3:19:26, charging stops, and charging current drops to zero.
but what i'm saying is that once those numbers go to zero, i can use the device for hours, and there is no drop. it just keeps pulling off the charger, while the battery numbers dont move at all. the result is that it trickle charges the battery while at the same time letting the phone run off the power cable, not the battery.
those zeros that show up are the draw on the battery. negative means its drawing current from the battery, positive means charging into the battery. the zeros that appear once it hits 100% and charger off message appears means that there's no battery drop after that.
Hmm. Very interesting. I see your point.
kos123q
