2.2 lock screen problem
1088933
Androidoholic
Apr 26, 2010
738
40
Anyone having an issue with the basic lock screen not working on 2.2? There isn't even an option check box for it. The only time I can get it to work is if I do a pattern lock or something of the sort but then I have to deal with both. Anyone else have this?
Sent from DROIDX using Tapatalk
Yep I can't even disable the lock screen. Which I miss. Have to remember this a leak and not official release
Yup. I, too, have no basic lock screen. The only way for me to get the slide to un- lock screen is to set either a pattern, pin, or password lock. Kind of sucks. Before I upgraded to 2.2, I had no lock screen turned off in 2.1. I wonder if that is why I have no unlock screen in 2.2.
I was wondering this same thing cause I had my pattern lock turned on at the time of the update... crazy things. Glad I'm not the only one though :)
pupso4ev
