2 XL notification LED?
modifier
893
I don't see a notification LED in the specs and haven't seen anything in video yet. Does the 2 XL have an LED or does it rely solely on the always-on display?
Thanks
re:
Oreo update it make it have it yes at least on the pixel it does so I would assume it does here to
re:
I think it's called like blink or something I can't recall not by pixel but it does have it in there now
re:
It probably has one. I can't remember the last phone that listed a notification light in the specs, but it's probably in the manual.
re:
Thanks
I'm not sure....haven't heard it mentioned at all.
re:
I don't agree. Nothing beats that blinking light you can see clear across a room alerting you to a text or email etc.
Previous pixels really fell down in this area the LED is so dim you couldn't see them well in a little room. Hope it's more like the 6P.
Not sure but i found a glass screen protector that has an odd cut out on far right on top of display.. looks like notification light to me
re:
Nice find. Thanks. The cutout under the speaker should be the ambient light and proximity sensors, leaving the random dot over on the right to potentially be a notification LED. Let's hope you're right!
re:
Thanks
You can take it to the bank....the 2XL has a notification light.
re:
Thanks. Sounds like between this and the reddit discussion above, it's a definite 'yes'.
But, the only thing I'm taking to the bank is a $900+ savings since I ended up canceling my order. Another device will be landing on my desk soon instead. :)
re:
What did you change to?
luigui443
