2100 m battery
t_kopta
136
6
This battery really isn't all that bigger than the standard battery however I'm having difficulty finding a snap on case to fit properly. Any suggestions??
Otterbox defender works but add some serious bulk. Also casemate pop fits extended battery
The Cruzerlite cases also fit the GNex with extended battery.
Sent from my GT-P7510 using Tapatalk 2
Thanks everyone I think the snap case I bought was defective. Even with no battery cover or battery it still didn't snap right.
You may have better luck with TPU cases as some have reported that they fit with the GNex extended battery. I have the same extended battery and I go caseless. It feels great in the hand and I have no complaints.
VZW GNex running CM10 Jelly Bro
Yeah I looked in all kinds of back alleys and strange markets but ended up back at Verizon getting a blue tpu. I'm happy but I really wanted my camo snap case dang nabbit!!!
The incipio case works well too
I found that the snap on cases fit better with the extended battery, less creaking.....its tight but it goes on,
Sent from my Galaxy Nexus using Xparent ICS Tapatalk 2
What snap on cases did u find???
cybrox
