30% battery drain overnight
nivekuil
The battery on my new s4 was at 40% or so when I went to sleep, and 12% when I woke up. BetterBatteryStats and Wakelock Detector report that it was in deep sleep >95% of the time, so why is this happening? I have most of the pre-installed bloatware disabled, and also have Easy Battery Saver installed. The phone was also on Power Saving mode with all options enabled.
https://www.dropbox.com/s/m8tmzs99bk7oq5l/BetterBatteryStats-2013-07-08_124341218.txt
Was the phone on WiFi or cellular? Also were you roaming or in a bad coverage area?
Sent from my XT881 using AC Forums mobile app
Wifi should have been disabled by Easy Battery Saver (it does so automatically after a period of non-use) and cellular was disabled. I did just notice that bluetooth is enabled, must have accidentally turned it on. Even so, should the battery drain be that severe?
I am also having battery issues.
I have screen brightness at 30%, I have power saver on. I have air gesture, eye control, voice control all off. I do keep 4g on constantly but I am draining 10% per hour with LIGHT use.. And I tried new batterie s and those are doing it to.
So what gives?
Its so bad that when I plug usb into my laptop the phone actually still drains as it charges.. But far slower.
If you are using the phone while charging off a laptop then it will most likely drain slowly and not increase battery life depending on what you are doing.
Was it a just out of the box new? Because I had pretty bad battery life the first day but it improved after syncing and dling all my apps. Has it gotten better?
rajaryson24
