3G problems after fixing ESN..how?
Status
Not open for further replies.
thecow
OK. I've been on this on and off for a month!
I got a Sprint LG Optimus S with bad ESN. I was able to repair ESN. Talk and text works. Web works. But I can only get 1x. Sometime I will see 3G. But 3G AAA authentication status from debug menu is always in pending state. I have copied NV item 465, 466, 1192 and 1194. They are from a perfectly working Hero. I did an similar experimental repair on another Hero with the same settings in the past and it worked really well. But Nooooo..not this LG!
Does anyone know how to get 3G after ESN repair? Where does Optimus S pull AAA authentication key from? I mean from which NV item? I would think 1192. EFS Explorer from QPST is no help because nfs and .efs_private folders are locked. Any idea?
I also posted this in the other Android forum too..hopefully someone will share the knowledge. I don't really need hand holding. Just need a finger pointing to the right direction.. Thanks.
I don't think you're allowed to talk about ESN modding at all here, even if you use the word repair.
Status
tombwiz14
