50% battery drain
Brylouton
7
I had a 50% battery drain overnight, running ARHD 6.1.1. with sense 3.0. Went to daemon controller and it said it did not support the kernel. Dialer 19% Cell standby 19% Cell idle 19%. Not sure what to do without reflashing. Any ideas?.
Was it working fine for a while and then just started acting up? If so, think about what changes you made before the problem arose and undo them one by one until you find the cause.
Reflashing may be the best option you have. And you could move up to 6.1.3 like I have:p
Can you tell a difference between the two. 6.1.4 came out today. What are the differences you notice?
What kernel are you using? I flashed the unity kernel and it seems to run a little better than klquicksall's kernel that's included in the rom.
6.1.3 was the first ARHD I used. I flashed 6.1.4 the other day. I don't really notice a difference, I just saw that it had an updated kernel so I went ahead and did it.
shamsa
