6.0.1 update seems to have made my Car Bluetooth problem worse ?!?
PaulQ
1,984
29
48
I got the 6.0.1 update and I had this little, tiny bit of hope in the back of my mind that maybe they snuck a fix in for the erratic connection behavior on many people's bluetooth car connection (me included). As a reminder, it connects, drops the connection, reconnects - all at random.
Since getting the 6.0.1 update, if I place a call via my car's bluetooth connection, the phone starts to place the call, I hear a "pop" and the bluetooth connection cuts off. None of the call is handled through my car and the car displays "Unknown Number" for just a couple seconds. The phone continues the call but its now through the handset. So, now I'm not getting anything through my car's system.
I tried rebooting my phone after the update. I tried "forgetting" my car and reconnecting it to the phone as a new device.
Of those of you that do have the car connection problems, did yours get worse? better? the same?
Under Google Connectivity Services... Clear Data
APPS > GOOGLE CONNECTIVITY SERVICES
No "Clear Data" option and, unfortunately, it shows it hasn't used any memory in the past 3 hours. No battery use either.
Am I missing something?
Tap 'Storage', then you can clear the cache and data for the app.
Sent from the Comm Center of the Trigati
Ah ha! Found it. Cleared it. Will try a call tomorrow on my way to work. Thanks guys!
Hmmm..... I had the opposite experience.
After the update, bluetooth in the car works as it's supposed to. Let us know how it goes after you you clear the data.
It works!!!!!!!!
Cleared data. Disconnected car. Reconnected car. Held a phone call for 15 minutes.
Thanks everyone!!!!
I just tried this as well. I hope it fixes my problem, where audio stutters intermittently. Before Android 6.0.1, Bluetooth audio always worked great.
Question within the question: Can you see track data now? I have an Acura TSX with a technology package and my LG G4 is on 5.1 but all I get is a "Bluetooth Audio" on the car's nav screen when playing music via Bluetooth. I had contacted Acura and they said that was on Google. I was hoping that when the G4 finally gets Marshmallow, the track data will also show on the screen.
Don't know... seems to be working for me....
Then it could be Marshmallow or your phone vs my G4. What year is your MDX?
Posted using SwiftKey on my LG G4 via the Android Central App
BT in the car connects fine for me, but is pretty bad quality. Before the update BT connected sometimes and didn't sometimes as well. What I have noticed with the little consolation speaker Huawei sent, it takes a couple of times to connect. This phone just does not like to connect via BT. Periodically happens with AW as well.
Kenorian your audio system looks more advanced than mine. You must have a newer vehicle or upgraded system. My TSX is a 2011.
Ah well, it would have been nice. My work around is a Kenu mount on the vent between the steering wheel and console. I use Caffeine to keep my screen on when using Google Play Music. Going back to the OP, my Bluetooth connection is very stable. I can drive for an hour without a disconnect.
Seeing track data on the navigation screen would be nice but without a true Android Auto touch interface, I'd still be relying on my phone for doing things like changing playlists.
sportzfyapp
