64 GB microSD for EVO LTE
Zach_AC
10
SanDisk - Mobile Ultra 64GB microSDXC Class 6 Memory Card - SDSDQY-064G-A11A
So I'm not familiar with class and types of microSD cards. Right now I have just an 8GB from my OG Evo in my Evo LTE. Will this microSD card work for those that have tried it and if so, is there anything I need do so that this microSD works?
Its on sale and it seems pretty good for the price. I just don't want to buy it and then not have it work or not know how/if I need to format it or something!
mrbuddy
15
I've read that you should format the card in the phone to increase your odds of success. I haven't seen a solid yes/no answer to this question.
KoukiFC3S
1,724
123
It will work. All you have to do is format it from the phone the first time you insert it.
Sent from my EVO LTE
Reactions: fubarsport
gmtom1
255
40
Yes, it works. Bought the same card and the phone asked me to format/erase it once I inserted it for the first time. Keep in mind that Windows will not recognize the format once you do it, so you'll need to do all your file transfers via usb cable or using a mac.
Also, you might want to consider what you're going to use all that space for. Pictures & music will work ok, but google music cannot save music offline to the external SD, and most apps cannot be moved to the external sd either. I bought mine thinking I could have google music put all my music offline on the external sd. (search & see the various threads).
a22matic
187
5
Yes, it will work. I bought mine a few weeks back, & used it in my OG EVO until I got the EVO LTE. Works flawlessly... I put as much on it as I can, b/c I want t keep the phone memory free & clear.
IRBanite
Active member
Dec 6, 2010
40
When you insert it for the first time, do you power down first, insert and boot back up or just insert while phone is on and it will recognize it and ask you to format it? Thanks
jcthorne#AC
177
6
Does the 4GLTE still have the 2GB file size limit? (not big enough for HD movies)
Could really use the storage for a few shows/flics when traveling.
dre22era
149
3
It does not. You have about 10 GB storage available on the phone, plus 25 GB storage with Dropbox so they figured they didn't need to provide one.
Thanks for the heads up
without even thinking about it I took my SD Card out my 3D and put it in this phone to retrieve my photos and thought I may have lost the new SD card for the LTE when I couldn't find one.
Anthonicia
188
19
Could've sworn I had movies over 2gb on my og EVO. It was rooted however. Have to try it out.
Also, for those that don't know. Class 10 is the highest class atm. It refers to the read/write speed. Class 4-6 should be sufficient on some better sd cards since they often surpass their rated speeds up to and beyond class 10.
Sent from OG EVO LTE with Android Central Forums
yauhn
