7 Edge or Note 7
JOHNGAETANO
212
9
18
Was going to pick up a 7 edge tomorrow, but should I wait to see what the Note 7 is all about? I've had notes before. Like the size, but dont find myself using the pen.
If you don't need the S Pen, then either would do. Just a few more days before official announcement so if it were me, I would wait.
From what the leaks have suggests the note 7 will have a bigger screen and a smaller battery. Seems like the S7 Edge would be the better pick.
Sent from Sir Cletus Sexy IV.
(S7 Edge Titanium)
Being is that the official announcement is in a couple of days I would definitely wait until then. Can't hurt and that way you won't kick yourself if it turns out you wanted the Note instead.
Might be a wash if there is a new CPU that is more energy efficient, making a larger battery a non issue.
I just keep a battery case in my car for my Edge7 in case I'm going to be out really late.
As some said.. depends on S-Pen use. I use mine so the Note is worth it.
