A little help please...
Stevez48
175
3
So I rooted using unrevoked 3. My process was as follows:
1) Back up contacts with back up assistant.
2) Download Unrevoked3 for Windows (running windows 7 ultimate)
3) installed HBoot drivers
4) turned on debug mode.
5) posered down and removed sd card to protect files
6) rebooted phone
7) Ran unrevoked 3
8) connected phone
9) unrevoked worked it's magic and said done.
10) phone successfully rebooted, and I was able to reboot to clockwork recovery
11) Powered off phone installed SD card again
12) Boot to clockwork and back up of system successfully
13) rebooted and all looks great on the phone.
14) Downloaded Titanium Backup - Here's where I get message saying "Sorry, I could not acquire root privilages. This application will *not* work! Please verify that your ROM is rooted and includes BusyBox and try again."
Questions:
1) How do I know for sure if I am successfully rooted? The fact I have clockwork should be it right?
2) What is BusyBox? Do I really need to download it?
3) Any other advice?
THANKS SO MUCH!!!
So..... Is it possible to run unrevoked again? Maybe something didn't work properly because I took out the SD card???
I did, I uninstalled it (Titanium Backup) and didn't get a chance to re-install it yet and try again. Still am not sure what Busybox is and if I need it though...
Re install Titanium run it and click or tap Problems in the middledown tab it will tell you to download Busy box click Ok after install you ll able to run Titanium allow the Auto superuser to run it
isaackse
