Accessories not Charging Rapidly
I got the following adapters and car charger that does not "charge rapidly," just a heads up. Did anyone else have similar issues?
Vinsic car charger
https://www.amazon.com/gp/aw/d/B014...ag=hawk-future-20&ascsubtag=UUacUvbUpU4791401
Spigen adapter chords.
Which I believe may be the corporate / reason for not "charging rapidly"
https://www.amazon.com/gp/aw/d/B00Z...ag=hawk-future-20&ascsubtag=UUacUvbUpU4791401
Did you try that charger with the USB C to USB C cable that came with your phone? Interesting being 5V/3A didn't bring up the charging rapidly message. I'm assuming that's your 1 star review on amazon? ;)
Posted via my 5x
The cord also matters. These are the cords I bought that show rapid charging
USB Type C Cable, Yoozon® 3.3ft/1m USB 2.0 Type C to Type A (USB-C to USB-A) Cable for Nexus 6P,Nexus 5X,Oneplus 2 and Other Type-C Supported Devices https://www.amazon.com/dp/B013187HZ...ag=hawk-future-20&ascsubtag=UUacUvbUpU4791449
USB 3.1 Type C Male to USB 3.0 A Male Plug Data Cable 6.6ft (2M), Hapurs High Speed USB-C Sync & Charging Cable Reversible Design for Apple New MacBook 12 inch, Nokia N1 Tablet, ChromeBook Pixel, Mobile Phone and Other Type-C Supported Devices https://www.amazon.com/dp/B00ZXT5K4...ag=hawk-future-20&ascsubtag=UUacUvbUpU4791449
They are working with my existing quick charge 2.0 chargers
USB Type C Cable, Yoozon® 3.3ft/1m USB 2.0 Type C to Type A (USB-C to USB-A) Cable for Nexus 6P,Nexus 5X,Oneplus 2 and Other Type-C Supported Devices https://www.amazon.com/dp/B013187HZ...ag=hawk-future-20&ascsubtag=UUacUvbUpU4791892
USB 3.1 Type C Male to USB 3.0 A Male Plug Data Cable 6.6ft (2M), Hapurs High Speed USB-C Sync & Charging Cable Reversible Design for Apple New MacBook 12 inch, Nokia N1 Tablet, ChromeBook Pixel, Mobile Phone and Other Type-C Supported Devices https://www.amazon.com/dp/B00ZXT5K4...ag=hawk-future-20&ascsubtag=UUacUvbUpU4791892
I think that I have yet to see RAPID CHARGING even with the stock cable and wall adapter....but charging is still pretty darn quick :)
It will only say rapid charging when the battery is at a fairly low level - if you are charging when the battery still has a good amount of charge remaining, the device slows down the charge rate.
Nexus 5X on AT&T - Posted via the Android Central App
Posted via my 5x
I was one of the 1-star reviewers. ;)
Yup, you were right! The charger shows as "charging quickly" with OE charger, and "charging slowly" with the spigen chords.
Had to return the cables I bought after review on amazon from Google engineer deemed them "not compliant"
gaige112
