Accidental edge presses with palm/hand
Zendroid1
Trusted Member
Aug 22, 2011
2,087
6
Edge users, do you find yourself accidentally having edge presses register on your phone? If so, are you using a case or not? I'm having some issues with my palm / hand registering and launching things a bit too often for my liking. I know the software update is supposed to help with this but is this an issue for anyone else?
I'm using a thin TPU case.
Samsung has rolledout an update...Hurry up and wait depending on your carrier.
I was getting this pretty bad when using the keyboard. Whenever i would reach to hit a key on the far side of the keyboard i was accidentally touching the side closest to my palm! I have since bought a case and the issue is ALOT better
Even a very thin case will largely eliminate this problem.
This!
I have two cases now, one is thinner than the other (both pretty thin... Liquid Crystal and UltraHybrid by Spigen) and they both cut down almost 100% of the issues I had with how I held the phone.
smith-jhone
