accidentally uninstalled power savering functions. Need help getting those settings back
3user
11
I rooted my m8 and removed battery manager accidentally. Is there a way to get it back . M8 is running sense 6
Yes you will need all preloaded apps on the device to accept an OTA.
From a Carbon M8 and AC Forums app
To fix this just reflash sense 6? And is there a place where I can find the img file?
That should work. Try XDA for the ROM
What app did you delete? I can can whip you a flashable Also are you on a stock rooted if not what rom. I need to know if its odex or deodexed.
My carrier is att. My phone is on stock rooted with one system app deleted (battery savings). And deodex.
download the rom and reflash if you dont still have ut on your sdcard. Remember Rule #1 make a backup in recovery and keep it on the sdcard so if something lke this or if you flash something and it goes wron you can restore and be good to go.
you can find stock rooted here.....One (M8) Android Development - xda-developers
boone
