Acer A500 connection issues
n8rfastback
5
Hey guys I am having an issue with my new tablet. I am able to connect to my home wifi and have no connection problems until I put my tablet to sleep and dont mess with it for a while. Once I turn it back on it wont connect to anything, none of the apps that need a network connection will connect and the browser etc, wont connect. The only way to get it to work again is to turn it all the way off, then start it back up again, then its all good again. Im not exactly sure how long it takes for the time-out to take effect, maybe ten minutes or so, then I have to restart it to make it work.
Hoping you guys have some info for me.
Thanks,
Nate
Sent from my A500 using Tapatalk
Looks like if I go into the settings and disable wifi, then reenable it, it will refresh and come back up, not a satisfactory fix though....
go into settings, wireless and networks, click on "wifi disconnect policy", then change it to never.
That's what I had it on.... now I have it set to turn off with screen off, and is reconnecting every time I wake it up and performing just fine.... we'll see if this holds up long term.
CGKalexander
