adb devices does not display my device
marcandroid
17
Hi fellow Android users
I will get straight to the point. I own a LG Thrive(Optimus variant) and I loaded the SDK. When I use the adb devices command from the C:\ it doesn't list my device. What could be the issue?
One of the recent upgrades to the SDK changed the file structure a bit. Make sure the SDK's /tools and /platform-tools directories are both added to your PATH environment.
  • On Windows, right-click on My Computer, and select Properties. Under the Advanced tab, hit the Environment Variables button, and in the dialog that comes up, double-click on Path (under System Variables). Add the full path to the tools/ and platform-tools/ directories to the path.
  • On Linux, edit your ~/.bash_profile or ~/.bashrc file. Look for a line that sets the PATH environment variable and add the full path to the tools/ and platform-tools/ directories to it. Or you can add it from command line: export PATH=${PATH}:<sdk>/tools:<sdk>/platform-tools
  • On a Mac OS X, look in your home directory for .bash_profile and proceed as for Linux. You can create the .bash_profile if you don't already have one.
Reactions: marcandroid
How will this allow my device to be displayed? also, the tools folder is located inside of the platform-tools folder so do i just add the platform-tools to the system path?
adb devices now displays device(problem solved)
It was a matter of installing the drivers for the Thrive(duuhhh). Installed drivers for LG Phoenix including the USB driver and adb devices now displays my LG Thrive:). Thanks to you all for your help.
Glad to see you got it up and running. Its like its the little things we forget. lol
dumpsterrentals104
