ADW Launcher Problem
candi3188
12
One of the reasons I started using ADW Launcher was because of the ability to rotate the homescreens on my Epic. I installed it yesterday and absolutely loved it, now it won't rotate into landscape mode. Has this happened to anyone? Any suggestions?
I have the Samsung Captivate and I just downloaded it a couple of hours ago. I saw your post and tried the landscape orientation on mine. I had no problems with it, sorry about that :( But your are correct that ADW Rocks!
Check your ADW settings (System Prefs > Home Orientation > Auto/Sensor) and your phone settings (Sound & Display settings > Orientation). With both of those checked, if it still isnt rotating, make sure you dont have a control widget for orientation locking it. Only other possibility is you are running an ADW theme that doesnt have landscape images loaded.
What happened is that I had checked "System Persistent" not knowing what it did. Unchecking it fixed the issue.
mimi
