Adware Problem
snakedoctor42
I have an LG v20 and I keep getting the Feeling Lucky (from the bottom right corner of my screen) pop-up at random times. Any help how to get rid of it? If I can figure it out, I will attach a screenshot.
Welcome to the forums. That looks similar to the swipe option included in ES File Explorer. If you have this app installed, disable it temporarily and see if the problem persists. Tell us how it goes for further assistance.
IIRC that menu pops up when you swipe up from the bottom right corner. Similar to the iswipe option in Clean Master and other CM apps.
Additionally I'd recommend using a different file manager app instead of ES File Explorer. Total Commander and Solid Explorer are both good and free of adware.
witnessloc03
