after jellybean, My voice commands are broken, My Girlfriends gnex voice commands work fine, help?
harleyb16
Active member
Jun 8, 2011
33
So if i say, for instance
"Navigate to chevron" - it performs a google search, instead of navigating.
if i say "call domino's" - oh look. a google search. that's helpful.
if i say "what's the weather like?" i get "the weather in denver, colorado is whatever" cool. I live in utah. (if i turn on wifi this one seems to work. but still, what gives?)
before jellybean, google search performed these actions, no problem. in addition, my girlfriends gnex does all this just fine. Can someone please help me? :'( i use to use this all the time so i didn't have to type while driving!
no help? does no one have these issues?
---------- Post Merged at 09:05 PM ---------- Previous Post was at 08:59 PM ----------
*semi fix*
if i open maps or something and let it find my general gps location. it works fine. can it not use an approximation? the weather tile uses a good approximation. but when i ask for weather without kicking up maps first, it gives me colorado. so bizzare.
For navigation, I use "take me to [insert location here]." Works fine. After the "count down" it opens up Navigation.
For the rest, I haven't used it for that.
Re: after jellybean, My voice commands are broken, My Girlfriends gnex voice commands work fine, he
Test your GPS... also clearing data in Google search then rebooting phone is said to fix problems like this
Thanks for that tip, it works perfectly!
---------- Post Merged at 01:14 PM ---------- Previous Post was at 01:13 PM ----------
Uninstalling Google Search, trying "Take Me to <contact name", uninstalling Map updates all didn't work. Any other advise to try?
I was having this problem as well on my gnex4 phone, then I Updated the google search app and everything started working as expected again. good luck.
joelkmason
